lain wrote:I've driving many cars that have overheating problems...they don't blow that fast...maybe i was just lucky.
On a car with a true ANALOG gauge, you have some leeway as the temperature rises from its normal operating temperature.
I can think of a car that has an "analog" (not really) gauge that doesn't do this... an '88+ RX-7. The temp gauge has three readings... "Cold", "Normal", and "Replace Engine".
Essentially, that's the system that our Versa has.Blue = Cold. No light = Normal. Red = Engine is fried.
Now, if you install a water temp gauge and monitor it, you will once again get that leeway and have some warning before the temp goes too high. But again, it's just cheaper and simpler to change the fluid preemptively.
I have FULLY overheated 5 cars in my life. 3 survived to tell the tale, and all 3 of those were water-cooled engines that were Subaru derivatives of the original air-cooled Beetle engine. I wouldn't do that to a modern Subaru, because if you look at it funny, it will blow a head gasket.
