steve_c »
https://forums.nicoclub.com/steve-c-u163301.html
Thu Feb 11, 2016 10:03 pm
A few thoughts:
Nissan Parts & Service Bulletin NPSB/07-027 dated Dec. 10 2007...
States concern over aftermarket flush machines that run a cleaner through the system.
They instruct dealers not to use these machines, as the flush agent may be harmful!
I have "flushed out" my system using only Nissan Matic fluid, I ran 16 quarts through the system to get
to a point of nice, cherry red looking fluid.
I think one concern about a total fluid changeout is that the proper amount must be put back, overfilling or underfilling are both detrimental!
When I did my flush, I monitored what I removed and what I put in using 1 gallon water jugs to capture & measure the old fluid being pumped out.
I replaced exactly what I removed, no more & no less, then rechecked level as per FSM.
I do not have a machine. I used the transmission pump to push the fluid out from a disconnected line at the transmission cooler, adding fresh fluid at the same time. The only problem is that the transmission pumps fluid out faster than you can add fluid into the charge tube, so you need to be careful, and utilize an assistant to shut the engine down when needed to avoid a mess!
If anyone wishes a copy of the Nissan Parts Bulletin, I can E-Mail it to them, or maybe a moderator can get it posted up to the sight for me.
