miata007 wrote:Well in the past, my cars don't get any types of transmission fluid for over 100k and had not issues (Honda, Toyota). So I was thinking drain and fill would be sufficient. That is also what's recommended in the owner's manual.
I am of course being cheap not doing a flush.
Thanks for the help!!
007
Personally I think if you were to centrifuge the fluid it would probably last much longer than your 100k unless you drive it very hard. What you want to do is remove foreign particles. To me the best time to do this is earlier in the life cycle of the device, in this case the transmission. So I would do a full drain and flush. After that simple drain and fills would probably be good for a long time.
My plan is at 20 k I will do a full drain and flush. About every 30 k or so I will do a drain and fill until about 100k.
I agree if you can afford it or have easy access to what you need then do a flush, heck do it every time you change your oil if you want, just not necessary and not cost effective.
Perry
