transmission fluid
luis.espinoza30
I just finished changing the radiator in my 06 M35, and I wanted to check the transmission fluid level...The owners manual refers you to the dealership....shocking isn't it!!!
Can anyone tell me how to check the transmission fluid on an M35???
bicsintegra
Car: '06 Infiniti M35
'06 Infiniti G35 Sedan (daughter's car)
'11 Ford F-150 FX4
'13 Ford Edge Sport
2020 Infiniti QX 80
luis.espinoza30
Sorry I didn't get back to you sooner....
I want to thank you on the link you provided, it was perfect....
bicsintegra
'11 Ford F-150 FX4
'13 Ford Edge Sport
2020 Infiniti QX 80
not a problem
luis.espinoza30
I noticed that the link was a PDF, maybe from a service manual? If so, I wanted to know if you could give me some info where I could get a service manual, and/or where I could get a PDF on changing the brake rotors...
Squeaky brakes are getting really bad and I wanted to change them out soon.....
Thanks again for your help
pedsemdoc
Car: 2013 M37 Sport - SOLD, Premium/Tech/Sport Journey
Carbon fiber engine cover
GT Spec front tower strut bar
R2C Intakes
Oil catch cans
Custom Start button LEDs
if you go up to your address bar in your internet browser and just delete "/at.pdf" so that it looks like:
http://www.nicoclub.com/FSM/M/2006_M45-M35
that will give you the index of all the FSM sections (the only problem is they are all abbreviated and not fully labeled, but you can save them to your computer and rename them.)
the brake section is abbreviated br.pdf
you may want to look up Brakemotive kit in search if you're looking for a cheap but quality replacement for your rotors
good luck,
Craig
luis.espinoza30
Thanks a bunch!!!!
luis.espinoza30
I tried to start my car this morning and had a lagging start with temporary chatter or clicking...I'm thinking it may be the starter and or solenoid which is what happened in the past with older cars...
Anyone had this problem before??
Also anyone know the abbreviated FSM section for starter removal??
