I suspect removing the fill plug will take care of that extra 0.6 liter of fluid.pmkls2 wrote:Filling it up by dumping it down the shifter is fine but there is a check plug on the side you need to remove to check the level, it will have a square head and take a 17 mm wrench. Fill it until fluid starts to run out of the hole and then replace the plug.
