transmission fluid mixture?
kpodj61240
Car: S14 Zenki
ok well i am about to put some redline in my transmission so i called to jkmotorsports in greenville nc and the guy there said he does a mixture of 1 full bottle of Red Line Super Light Shockproof Gear Oil and the rest of it mt-90. does this sound ok or better to do. it makes it a thicker mixturehas anyone done this before and can you tell me if it is or sounds better than just adding 2.5 quarts of straight mt-90
RedLine ShockProof is a revolutionary lubricant with a chemistry that significantly reduces the thinning effect inherent in conventional lubricant technology. Red Line ShockProof Gear Oils offer multiple oil film layers between gear teeth with absolutely no throw-off. Temperatures are dramatically reduced through unparalled gear tooth shock loading protection. The SuperLight may be rated a 75W90 Gear Oil with a lower internal fluid friction of an ATF. This weight is suitable for low horsepower applications such as FF1600 and Formula Vee
kpodj61240
Car: S14 Zenki
anyone??
homeslicej2
Car: 1990 Nissan 240SX S13 SR'd hatch
My advice would be to contact Redline's tech support and see what they have to say about mixing two of their products.
kpodj61240
Car: S14 Zenki
true true
