Transmission Fluid GL-4 GL-5 compatible
raynon2
Car: 1993 Nissan 240sx se KA24DE
Hi,
I am wondering if all the transmission fluid that claims it is compatible with GL-4 and GL-5 applications is safe to use in my 5speed 1990 transmission. About 2 years ago I swapped out my auto for the 5speed, but hadn't read up much on what type of fluid to use. I just threw in some GL-4- GL-5 compatible stuff and hoped for the best, but now my transmission is leaking a bit and I want to change the fluid to the right kind. I know it calls for GL-4 but I can't seem to find any GL-4 fluid, only the compatible stuff. I've been a few different parts stores in the area and no one carries just GL-4.
sjbsuperman1425
Car: 1989 Nissan 240sx
CA18DET
buy some Nissan MTF. I love it. Shifts smooth like butter now after switching from the multi-compatible stuff.
raynon2
sjbsuperman1425 wrote:buy some Nissan MTF. I love it. Shifts smooth like butter now after switching from the multi-compatible stuff.
I contacted my local Nissan dealership, but all they sell is the compatible stuff too! Maybe you guys south of the border have better access to this stuff?
sjbsuperman1425
CA18DET
I can get all that I want. The local dealer always has it for me
ricebike
2002 Quest
2005 Altima
i had advance auto parts buy me a case of redline MT-90 to have it shipped to their store & they'll call me to pick it up ~ that was before the internet boom; you can order stuff from an eBay seller or Amazon seller for the same GL-4 only oil
if you can't wait, local speed shops should have some
mogasman
Car: 2008 InfinitiG37 S
6-speed manual
GL-4 is obsolete. That is why you are having trouble finding it. GL-5 is the new standard and it backwardly compatible.
Mogasman - retire XOM Lube Engineer.
I am CLS certified by STLE.
raynon2
Ok, But I've heard on this forum that GL-5 can cause damage to the synchros in a 240sx due to its higher ratio of friction causing additives. Is this nothing to worry about?
sjbsuperman1425
CA18DET
Personally, I would stick with whatever Nissan recommends, and they recommend GL-4. That's just my view on it. check out www.thenismoshop.com. They sell the Nissan MTF.
ricebike
2002 Quest
2005 Altima
unless that other poster can post links saying GL-5 is safe for transmissions requiring GL-4 only, don't believe him
buy it online & have it shipped or goto local speed shops/ parts counter people & have them special order it for you
ricebike
2002 Quest
2005 Altima
the closest i can find about GL-5 is if it carries the MT-1 rating as well...
may be backwards compatible to GL-4, but at a certain temp
http://forums.maxima.org/fluids-lubrica ... 5-mt1.html
