FOR BRIAN TO READ YET AGAIN..................Q45tech wrote:When you disconnect the fluid flow from the in radiator cooler, the rear planetary gear IMMEDIATELY is starved of fluid, distruction will occur in minutes!
It is not like an engine where the oil just drains back into the pan, it only goes back into pan AFTER lubing the planetary.
If you have to ------just drain the pan - refill, then run the engine 2.0 minutes [stopwatch please] and pan drain again- refill, repeat for 4 times.
The fluid flow thru the system is 4 quarts per minute brand new.At 3 quarts per drain x 4 you should have most replaced.
What you don't want is to wait too long for all the new fluid to be back in pan when you drain obviously some mixing but having most of new in TC or cooling lines and not in pan would be best on next drain.
As the pump wears the exchange rate of flow lengthens but you don't know if it is 4 quarts per minute or 3 usually never longer [slower] than 2.5 quarts per minute flow.
Not 1 tech in 50 knows the flow rate thru the cooler/heat exchanger at idle in a Q. I've asked dozens they all guess wrong.
I missed the part where Dennis said this works as good as a mechanical fluid exchange.qship96 wrote:FOR BRIAN TO READ YET AGAIN..................
Hmmmmm....why is that, one wonders?Q45tech wrote:The correlation of 14 quarts [in a BG Machine] requiring 3 minutes 30 seconds to exchange is lost on many where a 10.5 quart capacity is concerned.
But as you documented with your second transmission, better to mechanically exchange the fluid every 15K.Q45tech wrote:I would rather see a member do a 3-4 quart pan drain and refill every 6 months than wait 3 years for a BG flush
Along with fluid degradation, one of your biggest worries right now should be whether your transmission filter is nearly clogged... a great likelihood.AlabamaDan wrote:Ok, don't flame me. I know I haven't been keeping my Q up to NICO standards, but I'm trying to make up for it now.
I've never changed my Trans Fluid and I don't know what the previous owner did. So, before I get it back out of the stable, I should probably do this.
I'm liking the drain, refill, run 2 mins, repeat, repeat, repeat. My reaons is that I've heard that one a transmission that hasn't been maintenanced well a "Flush" might cause more trouble that good. Is this just a myth?
Hmmm ... maybe, but lack of attention can still causes problems, IMHO. My 1995 Q45 had a transmission failure at just over 100k miles ... even though I did a full fluid flush at 90k miles. The previous owner simply had not cared about it enough.Q45tech wrote:Remember there is/was quite a bit of life difference between the 90-93 and the 94-96.
So don't compare limes to passion fruit.
It is harder to get longer life from a 90-93 even with 1st gear start just due to the stress from gear ratios and the lack of ATF filters and cooling deficiencies.
We see original 94 with 200k+ all the time.
Haitian_King wrote:I'm positively dying with laughter. Glad to see that I'm not the only one.
