voolover wrote:Did this a couple of months ago. New filter and pan gasket $27 at napa +16 Qts. of good fluid (dexron lll ) Undo the drain plug and let it drain. Undo the rubber flex hose at the radiator lower drivers side.
Here's where it gets fun........ Got an air compressor...? Good. Set the regulator to 20/30 psi and blow air back through the disconnected cooling line and watch another 3 to 4 qts drain. Hook up the hose, install drain plug and fill trans with oil...run engine till warm and shift thru gears. stop engine and do the drain routine like above but before you fill it up, undo the pan bolts and remove pan. Remove 4 screws holding the filter on and clean the pan. Bolt everything back together. Careful with the front pan bolts as they conflict with some steel cooling lines and you can strip the bolt holes in the case if not careful. Don't ask me how I know this. Fill it up ( I added a bottle of Transgard also ) and check the oil level when hot and your done!
This is a poor man's trans flush and works quite well...
Sorry to revive a very old thread, but I'm about to do the 60k mile trans flush on my wife's 04 Pathfinder (4WD LE Platinum). I used to own a 97 4Runner, and I have a question regarding flushing the Pathfinder's ATF vs. how it could be done on the 4Runner.
On the 4Runner there were two lines running to the transmission that 1) you could splice into to install a transmission cooler, and 2) could be used to do a thorough flush. Basically you disconnected one end of each hose, stuck one in a container of new ATF, stuck the other one in an empty container, and put the key in the ignition and turned it to the run position (without cranking the engine). A pump in the trans turned on, and you just left it running until old ATF stopped coming out of the one hose and new stuff did. Was supposed to be the most thorough ATF flush.
My question is, are there similar lines running to the trans on the Pathfinder? I would like to do a flush and install a cooler while I'm at it. I have the FSM, but couldnt tell from a cursory perusal of the auto trans section whether or not it was a similar system.
Thanks all!
