transmission fluid change procedure
In 2014, the G37 Sedan became Infiniti Q50. G37 Coupe and Convertible became Infiniti Q60 under Infiniti's new naming structure - Here's the place to discuss the Q50 and Q60!
molonlabe
Car: Current: 2015 Q50 Base, 2012 G37X, and a 2014 Honda Odyssey.
Previous: 2016 Q70L, 2015 Q50 Premium, 2017 Q50 Premium, 2018 Q50 Luxe AWD
does anyone have a step-by-step guide to changing the transmission fluid in a 2015 Q50 RWD? I have the online factory service manual, but it seems a little complicated/technical to follow..
That's the procedure.
The other option is simply to drop the pan (assuming there's no drain plug) and reinstall with a fresh gasket, then refill. This won't get ALL the ATF but about 60%.
If you want a full flush, any reputable shop should have a trans flush machine (or the dealer can do it).
Kompresshun
I know i'm a bit late here but the Q50 transmission is a sealed unit, so it's not exactly an easy transmission to service. There is no accessible filter either. Honestly i've weighed out doing it myself compared to what the dealer charges and it's not really worth it, at least for what my local dealer charges for the service. Considering how finicky Nissan/Infiniti transmissions are and how picky they are about the fluid I wouldn't take the risk.
audtatious
The 7sp fluid is supposed to last a lifetime and not need a flush, thus, why it's a sealed system.
Return to “Infiniti Q50 / Q60 Forum”
