fuzion »
https://forums.nicoclub.com/fuzion-u241.html
Sat May 15, 2004 6:58 am
1) Buy new fluid & rubber gloves*2) Put on gloves3) Unscrew "fill hole" plug [it's a pretty big screw, look under the drivers side of the transmission up towards the top]4) Place drain pan under drain hole5) Unscrew "drain hole" plug, on the very bottom of the transmission, use a 1/2 rachet [no socket obviously]6) Let fluid drain7) <still draining>8) <almost done>9) Put drain hole plug back in10) Use one of those nifty bottle pumps that will screw onto the gear oil bottle.. prepare for arm tiredation, as this will last 10x longer than your typical p0rn session on the internet, without the satisfying end11) Put filler hole plug back in12) Dispose of old fluid properly13) Remove gloves, if equipped -- see how clean your hands are?!
* Note about rubber gloves:I felt like a wuss when I wore these for the first time.. but damn it's so much easier, no grease or crap on my hands at all, gear oil is some really nasty crap, it's really bad for your skin, cancer = no good!
