Transmission fluid additives
timatt
I am getting ready to take my 91Q in for a transmission flush and will replace the fluid with Mobil 1 ATF. I've seen reference on this forum to 'BG' additives which are evidently recommended. However, I cannot seem to locate this topic using the forum search. Can someone tell me the recommended additives (I believe there are two) and the respective amounts of each.Thanks
timatt
Q45tech
BG Quick Clean for Transmissions is used for 15 mintes just prior to the flush exchange to free up the varnish and friction materials into the ATF [by running the car off the ground in all the gears including reverse to speeds] so they can be removed with the old ATF.
BG Conditioner is just a group of extreme pressure additives [Zinc organo phosphates] to protect the planetary and pump gears.
The future critical part is keeping the ATF temperature below the 200F range to extend ATF and internal seal life..........use the color of the ATF to tell you what is/has happened.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Tim.. I think your thinking of Lubeguard Red and lubeguard black..... Q451990 posted a thread about this thats just down this page..... Check it out!
timatt
Wes:
You are right. Any idea where I can get this stuff?
tim
VA99Q45
Car: 99 Infiniti Q45
I brought mine at NAPA.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Differences between Lubeguard Red and Black
"Red is synthetic sperm oil (can't kill whales anymore) and is used to smooth out the final engagement shock (lock-up.) It is a friction modified that lowers the coefficient of static friction relative to the dynamic friction. Dynamic is when the clutch faces are slipping past each other--static is when they are stationary.Black lubeguard increases static friction and dynamic friction coefficients, raising the locked-up torque handling capacity of the clutch unit (results in 'firmer' feeling shifts)
The Q45 TCU/ECU backs off on torque during the shift to give smooth shifts. For a given transmission condition/temp/oil condition, one can 'tune' the fluid characteristics somewhat. Factory settings are a compromise between smoothness, durability, and performance.Ideally you would get a continuous flow of driveshaft torque under all throttle and speed conditions, with no noticeable jerk or sag. Hard to achieve in this world.
You want to be careful with harsh shifts--they stress the metal parts and clutch faces (and driveline parts) more than intended. This is not to say they will fail (right away), but incremental wear/damage is unavoidable with hard shifts."
I am proabably really dumb, but I run no additives in any of my 3 Q45 transmissions. Shifts are crisp, but not jarring, but all were flushed while fluid was in pristine condition. Maybe I am just not sensitive enough to tell what they need.
elwesso
2007 BMW M Coupe
Then I must ask... Why does the valve body modification which gives us firmer shifts say that it increases transmission longevity...
AlabamaDan
Car: 2015 Infiniti Q70
1998 Infiniti QX4
Is a flush something that can only be done at shop? Can't be done at home?
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
elwesso wrote:Then I must ask... Why does the valve body modification which gives us firmer shifts say that it increases transmission longevity...
My undeducated guess is that at high power inputs it reduces the shift time, and thus slippage and thermal increases in the ATF.
The Infiniti (and other luxury car maker's) strategy of reducing timing advance at the moment of shift allows for a hisft at lower power, extending transmission life, but increasing shift time and decreasing performance.
