I was referred by Audtatious to this forum in the hopes of figuring out what could be wrong with my 2002 Maxima.
I posted this same issue on Maxima.org
http://forums.maxima.org/showthread.php?t=411251
And again here:
http://forums.maxima.org/showthread.php?p=4320809
To date i've tried using different gas from different stations, tried making sure it wasn't the transmission overheating and tried running on specific gears when the problem happens. New suggestions were to check the battery cables and check the wiring. (Which i'll try this weekend).
My car had 20 odd miles when i got it and now has 67k on it. Been in a rear-ender but no mechanical damage.
New Cliffs:- Recently the car, even when held in 1st gear, would jerk back and forth like it's trying to grab the gear (slip?)- While cruising, i lose all power for a short period (no lights, A/C turns off, etc). Then resumes- Though i wasn't able to try a transmission cooler, i doubt this is the problem as the 2 times it happened recently i just pulled out of the garage after it was being parked all day.
Old Cliffs:- Car jerks, shift's in and out/up and down- Completely loses power, takes several tries to restart- From a complete stop, engine dies when accelerating- No error codes, car is healthily maintained, Nissan reps can't find anything wrong- Has caused 5 near fatal crashes, might give up Max if can't be fixed
Please, can anyone help?
Thank you.- Mike
