Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Wed Oct 06, 2004 7:34 am
Remember the cooler drain return line DOESN'T go to the PAN FIRST, it feeds the critical rear planetary gears then dribbles into to the pan.
Why a restricted cooler/line takes out the rear planetary first!
Never try to drain and refill while the engine/transmission running without using an external membrane machine to maintain ATF pressure on rear planetary.
Simple pan drain repeated frequently enough will be 75% or better equivalent of a machine exchange without the circulating solvent flush..
If you are methodical and time the pan drain and run intervals with a stop watch, you can probably safely do a circulating chemical flush and fluid exchange with ATF without a machine?
Just reference the new ATF color on a white paper towel and keep changing [draining from pan] till the colors match perfectly.
Many times you will see that even with a machine flush and 14 quarts the colors don't match so another 14 quart flush is need for perfection a week later.............due to internal cross contamination [seal leaks].
Once you get it perfect annual flushes will keep it that way.
A perfect pump will move 4 quarts per minute at warm idle in park thru the cooler lines..........that is almost like measuring human blood pressure except the volume goes down [as the mechanical pump is fixed].
Owners can trash a transmission at 120k [or less] or extend its life to 200,000 + miles. Every day you don't have to spend $3,000 to replace one is a good day! Spending $200 per year on average on maintenance sure seems cheap compared to the replacement cost.
