Transmission downshift...?
00pathyse
Car: 2000 Nissan Pathfinder SE
2007 Nissan Altima 3.5 SE Sedan
Feels like my transmission isnt shifting down responsively as it used to. Sometimes doesn't shift down at all if i floor it form from a rolling start. Just wondering if there is an adjustment i can do myself? Suggestions? Thanks.
PapaSmurf2k3
Site Admin
Are there any CELs?
Sometimes when the TPS starts to go out, you can run into that issue. I'd suggest testing that first.
00pathyse
Thanks, i adjusted that not too long ago. It was set correctly running at idle i believe, but how do i know if it's malfunctioning? There are no codes.
PapaSmurf2k3
Site Admin
If I'm not mistaken, you should be able to check either voltage or resistance at idle.
I think the Factory Service Manual has a procedure on how to check it.
www.nicoclub.com/fsm
