oldmako »
https://forums.nicoclub.com/oldmako-u82911.html
Wed Jun 16, 2010 1:51 pm
Paul,
When I installed mine I eliminated the radiator circuit.
I have no idea if that was mostest properist, but it made the mostest senseist it me.
To Wit- Rad coolant is HOT (Normal operating temp) 99.9% of the time right??? So...how much cooling was that mother doing? I submit not one degree cooler than the coolant temp. So, to my feeble brain I think it maintained the trans fluids temp and only cooled it when it exceeded the engine coolant temp. Now, one could argue that the air flowing OUT of the rad and into the trans cooler is the same value and I cannot rebut that argeemint. Nor would I care to. I am very lazy and buy old used cars for a reason.
BUT...I drive my car on relatively flat interstate 90% of the time with only my corpulent and hail damaged and flabby behind, a suitcase, a set of goff clubs, and a spliff or two in the car. No big hills, no trailer. No spent uranium capsules, A10 ammo, extree batteries, birdshot, nuke fuel rods, fat chicks, anvils, or any other item with a high specific gravity. So theoretically, my trans temp OUGHT not get that hot. The mostest heinous thing I do to my transmotion is when I get stuck in bumper to bumper on a warm day.
So I just jammed the cooler in betweenum and forgot about it. That was 60,000 miles ago at 110K.
I also put in super jizz at the same time (M1 and Redline). The fluid is still nice and pink. I will repink in the near future. ("Nice" and "pink" tend to go nicely together don't you think???)
IF I were to do it again, I would put in a larger unit. I would self apply the biggest one that would fit in the interstice without overly heinous wrenching and modification.
In winter, I USUALLY let it idle for a few minutes at cold start up and then drive very gently (minimal throttle and no more than 2000 rpm) until the temp needle comes up to approx one third throw. This is when the car shifts into final gear. After that I limit my throttle application to the point where it bottoms out on the carpet and I try to keep the speed below about 110-120. That is of course unless I really have a need to get somewhere.
Beefeater Gibson up with a Romeo y Juliette 1875 Exhibition Number 3. Y'all be coo.
