Firewind »
https://forums.nicoclub.com/firewind-u40995.html
Fri May 15, 2009 8:18 am
a little grind isn't too uncommon for 240sx's. I am guessing it's when you shift from 1st to 2nd that you get a little grinding noise. It's not exactly healthy either, may want to look into getting some Pennzoil Synchromesh, I think I did a 1/3 Synchromesh and 2/3rds 90W gear oil in mine, and I didn't have that annoying grind. I am unsure of the wining noise though, could maybe be low on fluid?
But yeah, drive home, feel near your cat, if that thing is radiating a lot of heat, their is your problem. (Yeah don't touch your cat, ouchy burns bad.) I have seen cats that glow freaking bright orange their clogged so bad.
If you think youre's is clogged, drop the exhaust, and look at your cat, see if you can see any melted "honey comb" in there. That stuff is brittle ceramic stuff, you can break it out with a metal rod. (However you may want to replace it if your state has emissions.) Oh yeah, you'll wanna do it out side, that stuff is dusty and full of crap, wear a mask too, s*** is nasty to breath in.
Lemme know what you find out.
