Rev_D21 »
https://forums.nicoclub.com/rev-d21-u4222.html
Sat Sep 13, 2003 5:15 pm
Long time no see!
Between moving, working retarded hours and other BS I have finally found time to post here.
I post bringing you guys this write up. I will have pics up soon enough.
Hayden 403 Medium Duty Auto transmission Cooler Install.
The project is half done only because Hayden skimped on the hose line.
First off anyone who owns an auto knows that heat kills. They should also be aware that any kind of racing creates heat. Heat kills/Racing heat=Dead transmission.
I purchased this cooler from Pepboys for about $30. The box contains the cooler(looks like a small radiator), hold down clips and a small length of high pressure hose. Not enough hose to do the project but Haydens intentions were good I guess.
The install is going on my 97 Altima GXE auto. The car has been raced at the track consistantly for the last month. I dont want to destroy my transmission this early yet.
1_First part of the install was easy. Remove front grille. We all know how to do that.
2_Second find a suitable location for the cooler. I picked the passenger side of the condenser. It's a tight fit but the 403 will fit between the PS cooler line and the condenser. Go slow, I mashed a few fins doing this.
3_Once you have the cooler where you want it the box contains straps which go thru the find of the as well as the condenser and radiator. Poke those through and you will see the ends of the straps poking through the back of the radiator. Included with the kit are plastic caps which assist in locking the straps down. Slide these all the way down and trim off any excess plastic from the straps so the fan wont get caught.
4_Running the hoses. The cooler works best in series with the cooling part of the radiator. Take one hose from the radiator cooler and attach it to one port on the Hayden cooler. Now run a new line from the second port or the Hayden cooler back to the transmission.
5_Check for leaks and you are done. Check for leaks after a few hundered miles as well since it needs time to settle into the system.
6_Drink a beer.
Be sure the hose that you run has a burst pressure of atleast 150psi. Hayden only gives you about 3 ft of hose to play with, it doesnt reach anything. Fuel injection hose is not recommended as it has too low a burst pressure rating.
Enjoy a much cooler, longer running transmission. Best $30 you will spend in a while.
Oh and I am back now so get used to see me around here again!
Devin
