Transmission Control Unit
joes240
How expensive is it, and how hard is it to replace? Nissan said that's what is causing my hard shifting problem.
Bandit240
Car: 1980 Datsun 720 King Cab
The TCU is right above the ECU. Its not really hard to get to. If you need a new one i have mine from my 5sp swap. It works great. Its from a 1989 240SX Fastback
574-240sx
Car: Nissans, Toyotas, Subaru
I had the same hard shifting problems when i did my 5-speed swap. I went threw a clutch in less than a month because it was not releasing. Today I just rebuilt my clutch master and played with the petal height and now it is much better. You can get a Clutch Master rebuild kit from Adavanced Auto for $10.99. It takes about a half hour or so. Nick
joes240
How much would it be? I'd like to get it if you've got one just lying around so I wouldn't have to get a brand new one.
