evildky »
https://forums.nicoclub.com/evildky-u13100.html
Mon Jul 24, 2006 4:42 am
is the car suppoesd to beep in reverse? I'm not familiar with anything other than trucks that do this from the factory? also with the lights and no beep both stopping at the same time, is it possible you have the beeping backup lights that you can buy a any local parts store and they simply burnt out? again I have no experience with this but the beeping backup seems kinda wierd, also you say you have a display on your dash indicating gear? so this is an auto? (of course i don't think the 5 speed has a control midule either) in the 5 speeds the backup lights are triggered by a seperate sensor, not sure on the auto
and if the car is slow starting from a stop what if you put the car in first then try leaving from a stop? is it still slow? you may have lost first gear and could be in need of a transmission rebuild, or a dead servo or control module
have you had a diagnostic run? most mechanic's can hookup and look for codes in detail
