kylekinnamon1989 »
https://forums.nicoclub.com/kylekinnamon1989-u99656.html
Mon May 03, 2010 8:11 pm
1991 nissan 240sx Ka24de... ok, so im in the middle of replacing my clutch right now and i need a little help.. my car is supported off the ground with 4 jack stands. taking everything apart was not a problem, the shaft is out, crossmember off, starter, harness, shifter.. all off.. i got the transmission out but it was a pain, so whats the best way to put it back in with out hitting or breaking anything? and without a transmission jack, just two people and a jack! now, for the flywheel, the pressure plate was easy.. butt he flywheel bolts were a pain to take out too.. how the hell am i gonna put the new bolts in without the flywheel spinning? especially when i torque it to 105 ft lbs? any help is appreciated thanks
