Transmission Clicks
gmann212
Car: 2006 M35S
Looking for some info on a clicking noise happening when shifting from P to R then also while shifting through gears. It seems to happen more when its cold. I noticed for about a week just from P to R but now I hear it while in D too. Any help is more than appreciated thanks
BlackCat81
Car: 2006 Infiniti M35x
2003 Lexus GX470
2 things; it can be the brake pads shifting in the brackets, which can be resolved or lessened by removing the pads and lubricating the hardware kit. 2nd and more common issue (there's a service bulletin) is its the rear axle splines making noise where they go through the rear wheel bearings. Simple fix is to loosen the axle nuts, anti-seize the axle splines, and reinstall. I can get you the bulletin number when I get to work.
stevstep77
Car: Before 2009 Infiniti M45x aka BIGHEEM
Now 2015 Infiniti Q70L aka BIGHEEM2.0
I'm having the same noise but sounds like its coming from the rear axle. So would that be the rear axle splines as stated? Getting my mechanic to take a look see but i don't think they will find anything. But if there is a bulletin up about it I will want to take it to Infiniti and get it fixed.
BlackCat81
2003 Lexus GX470
stevstep77 wrote:I'm having the same noise but sounds like its coming from the rear axle. So would that be the rear axle splines as stated? Getting my mechanic to take a look see but i don't think they will find anything. But if there is a bulletin up about it I will want to take it to Infiniti and get it fixed.
Its ITB08-018b It states to use Molylote M77 grease which is some mega space age stuff found on Mars or something. I use anti seize in the area shown in the picture, and I also do the splines themselves.
Blackzilla
Car: 2007 Infiniti M45, 2014 Mazda 6
I had this exact same problem and the solution was what BlackCat posted. The click was very loud when I put the car in R or D and I had Firestone fix it. But now it seems like it's coming back I can hear a very faint click. Did you ever have a noise after you did this BlackCat?
gmann212
Car: 2006 M35S
Thanks for all the posts. I took it to the dealer today and they say they need to pack the rear axle bearings. Cost- $200. Is there a service recall on this to where it's covered?
BlackCat81
2003 Lexus GX470
gmann212 wrote:Thanks for all the posts. I took it to the dealer today and they say they need to pack the rear axle bearings. Cost- $200. Is there a service recall on this to where it's covered?
No M35/45 has packable or serviceable rear (or front) wheel bearings. So I don't know what they're doing.
BlackCat81
2003 Lexus GX470
Blackzilla wrote:I had this exact same problem and the solution was what BlackCat posted. The click was very loud when I put the car in R or D and I had Firestone fix it. But now it seems like it's coming back I can hear a very faint click. Did you ever have a noise after you did this BlackCat?
I've done a million of them and never had one come back. In my opinion, the noise is from the splines themselves, which is why I lubricate them in addition to what the bulletin states.
Blackzilla
Awesome thanks! This will be helpful if I ever hear the noise again.
TOMatBMR
Car: 2006 M45 Sport
This is something I have been needing to do for a couple months now but have not had the time. My lifts at the shop are always packed and I don't feel like doing it at home on my back. I did the front lower control arms and springs that way. I also need to do my front upper control arms but I want to save for the ones with the camber adjustments in them.
YELLOW PEARLGLOW
Car: 1990 300ZX NA Z32. 2007 INFINITI M35 advanced tech,journey,premium,dvd,reclining rear seats, 1990 MAZDA RX7 Convertible 13B rotary
I had this years ago and noticed the clicking when taking off from a stop, dealer took care of splines no charge and clicking went away
Blackzilla
How did you get the dealership to take care of it? Were you under warranty?
YELLOW PEARLGLOW
Was still under warranty
