mcastro »
https://forums.nicoclub.com/mcastro-u22582.html
Thu Jun 22, 2006 7:00 pm
I was going to ask the same question.
I just had my transmission fluid serviced using the BG Power Flush and Fluid Exchange. It’s been about 30,000 miles since I last had the standard pan drop/filter change and had Mobil1 synthetic ATF put in. The BG service I had done included the BG quick clean, and the fluid replacement with the BG Universal Synthetic ATF.
The one concern I had was that there was no filter change. The explanation given was that the flush actually cleanses the filter, which appears to be consistent with the BG protocol. I was thinking I would change it with the next oil change (if it's neccesary).
I have to say this stuff works great!. Shifting performance is noticeably better, it’s quicker, or at least more responsive to the throttle action, shifts under acceleration are much smoother. Shifting from reverse to drive, and vice versa, is completely passive, where before I could feel the gear change. It’s a nuance, but that's the kind of thing that reminds you of the Q's refined nature.
