satown210 »
https://forums.nicoclub.com/satown210-u230736.html
Thu Sep 20, 2018 10:42 pm
Transmissions and failures are a very unique situation with a lot of bad info.
The tranmsission should of lasted longer than 58K without maintenance. However as a mechanic and previous service advisor, I'd say the vast vast majority of people never service a transmission. People then cry and freak out when it fails at 150K. Then there is the rumors about fluid changing causing transmission failure. While I agree to leave it alone if it has very high mileage. But, a lot of people are prompted to do a fluid change because the transmission is acting up. Usually the transmission is already on it's way out. People change the fluid, the transmission goes out, (was going out anyways) and then people blame the fluid change. No, you had a failing transmission due to lack of maintenance and it was already damaged and worn. Sometimes it's worth the gamble. I had a Honda Accord with 200K+ miles. It would slip and stick in gear. I took it in and the shop refused to do a fluid change. At that point I figured I didn't have anything to loose. I did a fluid change and added a transmission additive and drove the car for antoher few years before I sold it.
