Yorb wrote:Here's the problem: strange, loud grinding noise when I depress the clutch. When I first got the car back after I blew up the clutch and had that replaced, it was doing this WHENEVER I put the clutch in. Now, after a week or two of driving, it only occasionally grinds, and generally not at all after the car has warmed up. I've just gotten into the habit of shifting to neutral at stops.
Sounds like a TO bearing, which should've been replaced when your mechanic replaced the clutch. That is generally covered in the cost of doing a clutch. If they didn't do it, then make them change it just because they should've done it the first time.
If they did change it and it's making that noise, then make them put a new one in, under warranty.
