nissanfreak12 »
https://forums.nicoclub.com/nissanfreak12-u177688.html
Wed Nov 21, 2012 8:29 am
650 is cheap compared to what other post on how much they paid, some have paid close to 2k! If you want the shops to stop taking you rmoney, learn to work on your own car. You will save time and gain some knowledge. Besides, wait till you have to do a timing belt change, parts alone will cost about 650.
The banging in first gear, are you absolutely sure its the transmission? Most things are connected in the transmission together, especially auto, and you should hear similar or any noises in different gears. Remember, first gear is the hardest on your car cause it has to move the car from a dead stop, all the other gears is just candy to it. lift your car up, check your drive shaft, make sure it doesn't move up and down. If so, center carrier bearing. Does the car make a thud instead of a banging, and its coming from the rear, differential bushings. Check the transmission mount, it easily could be out and hitting something while your accelerating. Check the fluid with the car running, make sure its not low.
If the actual transmission was "banging", something catastrophic is going on inside, and most of the time the auto's are not very forgiving.
On a side note, if you car is at 120k, maybe its time to do a 120k service on the timing belt. When was the last time this was changed?
