transmission acting strange
Beermoney
Car: 2001 Infiniti QX4
my 2001 qx4 started to not respond to the tow-haul switch on the shifter. about the same time the torque converter started unlocking for no reason. now it will sometimes down shift at highway speeds on flat roads. other than that it shifts very good.i am thinking some sensor somewhere. any ideas, anyone.
mdmellott
Car: '13 Kia Soul+ 2.0L AT
Beermoney wrote:
Fri May 21, 2021 5:37 pm
Are you referring to the O/D Off switch? When you say "torque converter started unlocking", are you saying it completely frees up like it's in neutral? :confused:
Beermoney
yes overdrive switch and no not in neutral but unlocked.
mdmellott
If your ATF level is good and there are no DTC codes being flagged, I have no idea where to even start with diagnostics for this.
Beermoney
anybody
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
If there are no DTC's then it sounds like a bum Torque Converter clutch. I doubt it's electrical, a weak coil would be diagnosed by the TCM. If you can get a scanner with work support that lets you manipulate the TC clutch solenoid, switching it on in gear at idle should instantly stall the engine. If it doesn't then either the solenoid is mechanically leaky or the TC clutch is bad or slipping.
