transmision oil change, which oil?
Mesarina
Car: 94 180sx
which oil should I use on a 94 180sx (black top sr20det) with a 5speed transmission.
the trans is experiencing hard shift on 1st gear when the car is moving...
Thanks nico
Lev_96_240sx
Car: 96 240sx
Redline MT90 (among the best) or if you're feeling baller and want spend a bit more doh, get Amsoil (the best). We have a dealer or two on this site, check them out.
Mesarina
Car: 94 180sx
Lev_96_240sx wrote:Redline MT90 (among the best) or if you're feeling baller and want spend a bit more doh, get Amsoil (the best). We have a dealer or two on this site, check them out.
Thanks, which weight oil are them?
Didderson
Car: 1990 Nissan 240SX FB
'88 Nissan Hardbody pickup
'74 Datsun Z
http://www.amsoil.com/storefront/mtg.aspx
Probably the best available for our gl-4 applications.
By the way, you won't ever be able to shift to 1st while moving unless you grind. It doesn't have a synchronizer so the gear teeth won't match up easily at high speed. Most every standard transmission is like this on any car.
Modified by Didderson at 10:39 PM 2/24/2010
Aoshi1
Car: 1995 Nissan 240sx
I would go with Amsoil as well, or Royal Purple.
Morph
Car: 91 Sr Powered Coupe
Didderson wrote:By the way, you won't ever be able to shift to 1st while moving unless you grind. It doesn't have a synchronizer so the gear teeth won't match up easily at high speed. Most every standard transmission is like this on any car.
All of the standards i've driven i can get it into first with the car moving. Granted im not moving 30 mph put 1 or 2 it slips in no problem
zach-Ka
Car: 1990 240sx (SR)
I use royal purple and am very happy with it's quality... 75-90 is what I used. If you can afford it though get ams-oil. I only use royal because its readily availible.
brizanden
Car: thrased kouki ftw
penzoil syncromesh works just as well as the 90wt royal purple i used. and im pretty sure the syncromesh is easier on our brass syncros
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Or just download the FSM's maintenance section and use what the recommend. They did make the trans you know.
Morph
Means nothing, use maple syrup works the best.
Gabes13
Car: rb20det s13
Morph wrote:use maple syrup
Razi
Car: Moo
OM3GA
Car: A Sexy Mobile, 1993 Nissan 240sx 180sx Hatcher
Sweet i still like royal purple the best for some reason.
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
Coastal 75w90. Its cheaper than Windex, just like s-chassis transmissions.
Didderson
'74 Datsun Z
Give me a break dude. I type 1 phrase (high speed) wrong and someone has to say hey I can get it in while moving!
Well yes I can too . The point is it won't be easy most of the time and it's not easy because there's no SYNCHRO.
Also I would advise against royal purple synchromax because it's made for gl-5.
I use the maxgear by royal purple with penzoil synchromesh added into it because it failed the copper wear test that I read, but then the test was conducted by amsoil.I want amsoil next haha.
Modified by Didderson at 9:38 PM 2/25/2010
