Transitor Unit
J30T_
Car: 93 Infiniti J30T
Well yesterday I toke my car to my mechanic and after about 2 hours of diagnosting the car he came to the conclusion that it is my transitor unit that is causing my car to miss fire.....its only running on about 3 cylinders..........I was Wondering if the transitor unit can make that happen??????????????And why is it so expensive for a transitor unit??
Thank you for all your help
gr8scott72
Car: 1994 Infiniti J30t
J30T_ wrote:Well yesterday I toke my car to my mechanic and after about 2 hours of diagnosting the car he came to the conclusion that it is my transitor unit that is causing my car to miss fire.....its only running on about 3 cylinders..........I was Wondering if the transitor unit can make that happen??????????????And why is it so expensive for a transitor unit??
What part is he calling a transitor unit? Does he mean transiStor unit? If he does, what part is the transistor unit?
Is he talking about a coil pack?
J30T_
yea he means the transistor unit....the part is just a little square box with a chip in it and som kind of gel......basically what it looked like was the gel got so hot and thats what caused it to go.....but im new to most of this and I really just need good advice...thanks
gr8scott72
J30T_ wrote:yea he means the transistor unit....the part is just a little square box with a chip in it and som kind of gel......basically what it looked like was the gel got so hot and thats what caused it to go.....but im new to most of this and I really just need good advice...thanks
I have no idea what part you are talking about. Get him to show you the part. A picture would be great.
J30T_
This is the piece the little black square piece..
Thanks
gr8scott72
Thanks
I guess I don't even know where that goes. Did he show you where on the car it is?
J30T_
Yes it is above my engine it plugs into a wire harnest
It's $340 from the dealer with NICO discount.
Try a used one off another car first.
elan
Car: BMW 328I, Had J30 95,
for my background in electronics this does not sound reasonable.
transistors will most likely cease completely than work half-and-half
you need to find an oscilo-scope and check the input and output signals and see what is happening on both sides, or as others have said find a one from another car and check first before investing that money into such an expansive part.
Gerardjg
Car: 2007 Cobalt LS
2011 Hyundai Accent
2016 Kia Optima
Wow aftermarket ones are $400.00
http://replacement.autopartswa...false
J30T_
Well here is the weird thing I changed the transitor unit and now 5 cylinders are running and one still is out and its needs an injector......I am wondering if my mechanic is doing somthing sneaky??? Cuz when i brought it to him 5 cylinders were running and then after him touching it 3 were only running and i needed a Tran unit......But my transitor unit was cracked... I need advice that
Thank you
95-J30tt
Car: 95 Infiniti J30tt (Twin Turbo)
ok so if you have changed the ignitor chip and it didnt do much.... perform a power balance test (it is easy, you can do it yourself without help), get the engine to warm up a little.... take one plug off at a time (blue arrows in the attached pic), each plug when removed, should drop the rpm slightly and cause the engine to shake, if you have a gas/spark problem, one of your plugs will not change the way the engine runs, that will narrow down your search.... do that and then update of what you get
http://q45.org/gallery/v/car/spark.JPG.html
J30T_
You have been a huge help thanks!!! Im gonna try it tonight and give you an update tomorrow!
Is it easy to learn how to change and injector yourself?
95-J30tt
if you have a dremel and a vacuum, you could do the replacement yourself (one injector at a time)
yodawill2000
Car: 94 Infiniti J30
Just a FYICarlos (Fuzzycats.com) has said that only 1 injector requires plenum grinding.I havent had too ,,, Yet
