Transimission Question
mkimister2
Car: 1990 300zx na
My mom's transmission went on her 97 infiniti qx4. She offered the car to me and i picked it up for a couple hundred dollars. I have the new transmission ready to be mated with the transfer case but the one spring popped out and I dont know how it goes. Here is a picture to explain what I am talking about: Is this set up correctly and if so why does the spring always pop out of its position. Thanks, Andrew
Good question - Let me see if I can get someone in here to answer this for you real quick.
Nice deal on the QX, by the way - and welcome aboard!
Raxephon
Car: '04 RX8...for the moment...
Look at the mating surface on the transmission, that is definately not correctly mounted.
1997 Infiniti QX4 FSM http://phatg20.net/modules.php...d=216
Modified by anlasak at 7:28 PM 4/25/2006
Modified by anlasak at 7:54 PM 4/25/2006
mkimister2
Car: 1990 300zx na
Thanks for the help, greatly appreciate it.
NISTECH
Your missing parts man. Most importantly the adapter case that allow the trans to connect to the transfer case. It looks like you bought a 2WD trans and took the tail housing off of it. Without the adapter case you have no hope of connecting the 2.
mkimister2
Car: 1990 300zx na
i have the adapter case that connects to the transfer case, thanks for scaring the ish out of me. Ill go make sure it is correct though. Am i missing any other parts? thanks though Andrew Edit: Here is a new pic i got that shows the setup correctly, I hope. Can some one verify this? Thanks for all your help
Modified by mkimister2 at 12:16 PM 4/26/2006
NISTECH
That looks right. now does the adapter housing bolt up to the trans correctly?
mkimister2
Car: 1990 300zx na
Yeah i checked that when i made sure i have everything. thanks for the help, i appreciate it . hopefully ill get it running this weekend and get some pics up.
