Transimission error code P2859
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
soumya35
Car: 2014 Nissan Versa
Hi All,
I'm having issues with my 2014 Nissan Versa, CVT transmission. At high speeds (around 65-70 mph), the car jerks occasionally. It's fine at lower speeds (20-30 mph), but the jerking happens about 10% of the time. I got it checked at a Nissan dealer, and they found a diagnostic trouble code P2859, indicating a 'Clutch 'A' Pressure Disengagement Performance' error. They suggested replacing the entire transmission, which costs $5500 :mad: .
I initially postponed the repair due to the high cost. However, a week later, the check engine light came on, and now I'm not sure what to do.
I'm looking for advice on a more affordable solution. Any help is appreciated.
Thanks.
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
P2859 is usually a death code for the planetary gearbox. You can try fresh fluid, but I wouldn't get your hopes up. I'd say 95% of the time the planetary is done and it's time for a transmission.
Return to “Versa Technical Discussions”
