The Transgo kit has been available for some time now and the part number is RE5R05A-HD2. Transgo is the manufacturer and will only sell the kit to certain shops, I bought my kit from Forged Performance back in February. The site only lists it for the G35/350Z 05-07 model years, but from what the tech at Trango said "it will work with all RE5R05A RWD transmissions" and also Shariff at Forged Perf said that he'd "done a few 08' G and Z cars with the rev match and it worked fine" so I bought it on the pretense that it would work - and it does!New2Import wrote:I have Trans Go on all my vehicles. Thats how it works basically at WOT you feel the shifts. Its more of quick than hard. If you get it too hard it will hurt something in the transmission. Meaning if you are barking tires on the 2nd shift thats too hard. Glad to hear the news. Did you let Trans Go use your car for the kit? When will it be available?
Good!ken in az wrote:Also it was good to drop the pan and clean everything in there. Not that it was junked up, but 45K mi on original fluid and it was a little dark and smelly.
I don't know if I'd do a flush, just replace the fluid. There is no replaceable filter in these transmissions, just a metal screen filter that actually had some stuff in there as well. A good servicing would include a pan drop and remove the filter to be cleaned. Then loosen the VB bolts to drain the rest of the fluid - you'll get about 2 or more quarts of the old stuff out of there when you do this. Then tighten it all back up, reinstall the filter, then clean the pan and the magnets and you'll be good.szhosain wrote:
Good!
It's why I recommend flushes at every 30k miles for real long-term transmission longevity.
Z
Yeah, I did it at my house yesterday, I don't recomend it to the average person - it is on par with an engine swap in regards to difficulty. Even then - unless you've done transmission work I highly don't recomend you do this mod. Too many things to go wrong.YMm45 wrote:this seems like a nice upgrade did you install it your self
You have it TOTALLY wrong on this one. Computer controlled vehicles the transmission pressure has to be raise to shift hard. These Trans Go kits reprogram the shifts for a quicker shift meaning there is virtually no slip in between or lag on shifts. That is mistaking for hard shifts which its not. Now if you do a Trans Go and raise transmission line pressure too high you bark the tires on shift thats considered to be a hard shift and thats not good on the driveline. On the break-in you usually use grease to hold the balls in place and its a good idea to cycle the transmission without being harsh to make sure it shifts properly and dont release a ball to hard and it get stuck in the hole. Ive seen this happen before. You want even feel it shift with normal driving. It will be just quick and feel MUCH firmer and not lagging on the shifts. Now at WOT it feels oh so good and snaps the gear so you will feel it. Once again that is mistaking for a hard shift and its not. This prolongs the life of the transmission because it keeps the heat down on the clutches because slipping causes heat. You might not feel the slip but its there and if you drive a car with a Trans Go kit you will put it in all your cars. Trust me I have them on all mine and plan on doing this one down the road.M4T5 wrote:I agree with your statement about not flushing transmission's. People don't seem to understand what bad things it actually causes. I have never flushed a transmission in any of my vehicles. Always a drain, filter change (if applicable), new gasket, clean the magnet & pan, and refill the fluid.Flushes are bad, and people need to come to terms as of why that is.
I don't know if I would do this VB mod. Having steel check balls in a shift kit usually make the shifts too hard..."usually". I prefer custom weighted plastic check balls. They don't allow the shift too be too harsh. This really only helps if the shifts already very harsh to begin with.
Also, what is there to actually break in with the VB mod to have to allow break in? A check ball? Just...curious....??
J
Nothing to break in, just "supposed" to give time for the VB to bleed all the air out. I think it's just all in the imagination of somone with an overactive sense of hydraulic knowledge, or they could be right. It's easy enought to take it easy for a few hundred milesM4T5 wrote:Also, what is there to actually break in with the VB mod to have to allow break in? A check ball? Just...curious....??
J
