Transfer case servicing
AllTheTimeInTheWorld
Car: 2001 QX4
O.K, I've been scratching my head over this since Sunday. I drained my transfer case Saturday, got close to 3 quarts out, and got less than 2 quarts to go back in. Has anyone else experienced this? It should take 3 1/8 quarts I know. Also, has anyone pulled the transfer case filter? Town said it cost like $115 so I'm thinking it's a mesh strainer that can be cleaned and inspected rather than replaced. Any ideas? Thanks.
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
If you'd like, you can remove the transfer case filter and see what it is. To reinstall it, you'll need a couple new O-rings:
[15226X] SEAL-O RING
[15226XA] SEAL-O RING
Provide your VIN and I can provide exact part numbers.
Car: 2001 QX4
Well, no matter what I've tried it will only take two quarts. I pulled the transfer case filter and cleaned it with brake cleaner and compressed air. It does appear to be a screen rather than paper element; at least no paper pleats showed. Takes two O-rings on the filter itself and a third on the pipe that runs into it from the transfer case. They were in good shape so I re-used them.
