Transfer Case Service + PCV valve costs
bejjutsu
Car: M35X ('06)
Are there any telltale signs that AWD fluid is low or needs replacing? The dealer wanted to "service the transfer case" around 70K (now @ 75), even though it would have been done at 60K, and the interval is every 30K. What should this cost?
Second part: is there a PCV valve people recommend?
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
The transfer case should be a simple (well, depending on access of the fill and drain plugs) drain and fill of the fluid. Not sure how much this will cost, I'd imagine it depends on the specific dealer. My local Nissan dealer would probably charge $25 + disposal fees, tax, etc. if I supplied my own fluid. You can DIY if you'd like, page MA-32 of the factory service manual has details.
Use an OEM PCV valve only, I've read of horror stories of aftermarket PCV valves causing more oil consumption, early failure, etc...
06M4.5
Car: 2006 M45
I asked my dealer sometime ago and they told me $129 just for the rear on my M45. WHAT A RIP OFF!!!! :facepalm:
bejjutsu
Car: M35X ('06)
To be clear, I'm not going to have the dealer do any of this. Last oil change I had them inspect it. They wanted over $100 for the PCV change alone.. I'm not really a DIY guy and I don't have a space to work on it, so the plan is to buy the parts and go to a reasonable mechanic.
