AllTheTimeInTheWorld »
https://forums.nicoclub.com/allthetimeintheworld-u193805.html
Sun Jul 08, 2012 1:04 pm
I have a 2001 QX4 with a rattle that is bothering me primarily because I'm not sure what it is. Usually it's really noticeable when you first take off in the morning and quiets down significantly the rest of the day. It rattles loudly when accelerating from a stop and quiets down at higher RPMs. As it shifts to second you can hear it again until you get to higher RPMs again. At first I thought it was an exhaust shield coming loose, but after pushing, pulling and tapping around under the car I've found nothing loose. Then I thought it may be in the transmission (sound seems to be in that area) so I dropped the pan and changed the filter and fluid (fluid was dark, but no burned smell); no change. Last night I drained the transfer case (fluid was black but didn't smell burned). I drained about 3 quarts out, but only got about two quarts back in. This morning I took it out for a drive and the rattle was noticeably worse. Two things: 1. I checked the case fluid level when I got this car and the level was good (wish I'd changed the fluid then given how dirty it was). How is it I got three quarts out and can only get two back in? Are there two service plugs? The car was sitting level in my garage. 2. Does anyone have any ideas about the rattle? Thanks.
