Transfer Case Plugs - Gray Goo?
Discussion forum for the Infiniti JX35 / Infiniti QX60 - This 7-seat premium crossover dominates the class.
yeller
Car: Infiniti JX35
I replaced the transfer case fluid on my JX35. Other than the filler plug located in a weird / horrible place, it went well.
The transfer filler and drain plug had a gray goo sealer on the threads. Anyone know what the gray sealer is?
BTW, differential fluid replacement is super easy and red thread lock is used to seal the bolts.
Ilya
Good work! You sure it isn't just 'debris' (for lack of a better word) from the transfer case that accumulated on the bolt? Like metal shavings or what not?
yeller
Car: Infiniti JX35
It definitely wasn't junk from the transfer case. Reminded me of pipe putty.
BTW, has anyone changed their transfer fluid in the past? The case actually has two filler holes, one with a 11mm bolt (slightly above the drain) and another "plug" that accepts the 4-sided 3/8 ratchet higher up (and even harder to get to.)
I originally added gear oil to the 11mm bolt (took ~11oz) then went back and added more via the 3/8 plug (took another 15oz - ~25oz total). Anyone know why the case has a lower fill bolt?
And PLEASE tell me I didn't add gear oil to the wrong fill hole.
Ilya
I'm having a tough time visualizing the underside of the vehicle right now but on my M56x, the lower is the drain and the upper is the fill. Not sure why there would be 2 fills...
yeller
Car: Infiniti JX35
I agree, it's a pain. Here is a pic I pulled from JX35 transfer cases on ebay.
http://img4.imagetitan.com/img.php?imag ... ercase.png
Ilya
That's odd indeed, can't say I've ever seen that.
macgiver
If somebody was doing it smart , could be anti-seize . I use anti-seize on the threads , on the shoulder of the
'plug' , in liberal amounts .
Makes very easy to remove next time , and also actually prevents leaks ( tork it right ), as it ages in time.
https://www.permatex.com/products/threa ... d-sealant/
Not necessary, but I see a lot of shops use it just for security.
yeller
Car: Infiniti JX35
AZhitman wrote:
Fri Aug 14, 2020 10:29 pm
Permatex 56521 is white, but probably grayed over time.
Must be it. Thanks AZhitman
Mtech2
Car: 2019 Infiniti QX60 AWD Pure with Essential Pack
2017 Rogue SV FWD
2009 Ford Flex SEL FWD
It is pipe sealant. The plugs are supposed to be 1x use, but most people will re-use them without any issues.
yeller
Car: Infiniti JX35
oh... Good to know. Looks like I have some plugs to buy in 30k miles.
Hopefully 4+ years given no travel work life.. :)
Return to “Infiniti JX35 / QX60 Forum”
