Transfer Case Output Shaft
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
brianzero
Car: 1986 Nissan 720 4x4 Regular Cab 265,000 mi! (Gasser unfortunately)
I have some play on my 4x4 transfer case output shaft, where the rear drive shaft attaches. It seems like the play is on the output shaft itself. What would be the cause of this? My guess is a bad bearing on the output shaft. How hard is that bearing to pull?
PEZi
i don't know a lot about the 4wd transfer cases.... but it sounds to me like the carrier bearing... don't take my word for it tho
it is not an impossible thing to change.... but depending on your level of knowledge it can suck
brianzero
If the transfer case is built like a manual transmission, then I should be able to open it up and remove the bearing...after battling it for hours. This truck doesnt have a carrier bearing as far as I can see.
Does anyone have an exploded view of the transfer case?
captainzeros
Car:
1981 Datsun 720 Longbed
1973 Datsun 240Z
Ask and ye shall receive:
brianzero
Kick a** captainzeros. You guys think these bearings are common, as in found at NAPA as generics?
captainzeros
Car:
1973 Datsun 240Z
looks like www.rockauto.com has them. Reviews for rockauto are a mixed bag, I've had nothing but awesome luck with them, some people think they're satan.
If you do buy from rockauto, google up a coupon code, they have ongoing customer loyalty coupon codes for 5% off that they suggest sharing with your friends.... the internet is my friend, right?
brianzero
Ive had mixed luck with rockauto. If you ever have a return or an RMA, its hell to try to find where to send it or how to get credited for it, mostly because their customer service is in the Phillipines......ask me how I know this!
The moral of the story is make absolutely certain the part you order is absolutely correct, that being said, there are several different bearings for the same output shaft on this transfer case on the rockauto site. Ill bet that because its an old truck, NAPA can cross reference the bearings to something generic in their local warehouse.
Basically, Ill need to pull the bearings and look for the ink stamps. As far as those weird needle bearings, who knows where Ill find those.
Yo captain, have you ever been inside one of these transfer cases?
captainzeros
Car:
1973 Datsun 240Z
Nope, my truck is rwd, just got a service manual and a nice scanner. (and a haynes too)
brianzero
I thought because there was a big greasy thumbprint on the page that youd been doing some work 'on that page'.
Off to change my ball joints this morning!
captainzeros
Car:
1973 Datsun 240Z
Oh, haha, every page of my FSM is like that, it used to be in the library at a mechanic's shop.
flinterman2000
Car: 2000 Nissan Wingroad, 85 Datsun 720 Pick Up.
Can't handle that. If you're gonna use any of my books I aint got a problem with that but you betta have clean hands. All my manuals and magazines are pristine.
brianzero
Then definitely dont lend any FSM's to me, if you know what I mean...
Return to “Datsun 720”
