Pezgoon »
https://forums.nicoclub.com/pezgoon-u212141.html
Wed Nov 14, 2012 10:03 am
I went to change my transfer case fluid in my (new to me) 2002 pathfinder le 4x4 yesterday and as I opened the filler plug, probably a good half a quart came out of it.. It has 136k on it and the previous owner had no idea if its ever been changed, it was pretty black when it came out... After draining it, it filled almost 3 quarts in my measured jug (about 2.75 and the amount that ended up on the floor probably adds up to 3) i guessed that the ride height has changed from towing (last owner towed) and from age causing the fluid to come out the filler plug... so i jacked the rear end up 4-5 inches higher than the front (originally it was about 2 inches lower than the front...) after starting to refill it I only was able to get 1.8 quarts in before it started leak back out of the fill plug... So what should I do? I have an all time 4wd transfer case and the service book lists the capacity at 3.2 quarts... Should I continue jacking up the rear until I can fit all 3.2 quarts? Can anyone tell me the stock ride height so I know how high I should jack it? If anyone could please help it would be much appreciated!!!!
