Transfer case leak after change/top off
TheScarletRogue
Car: 2015 Nissan Rogue, Cayenne red
Ok, so I did a diff and transfer case oil change on my 2015 Roge AWD on Sunday, since then I can smell burning oil when I drive. I put it on the lift and took a look and no signs of leaks from the plugs, but there was oil on the exhaust heat shield (I cleaned it with a rag a brake parts cleaner after I changed it). When I filled it, I filled it untill oil just started to trickle out the fill hole. Was this correct?
Rogue Jarhead
Car: 2011 Nissan Rogue Krom
If you don’t have any leaks just drive it. The oil smell will go away. Anytime you get oil on an exhaust component it takes a while to go away. Recheck after a 100 miles or so if the oil is back on the exhaust sheild where you cleaned it then you’ve got a leak.
Filling it till it starts to trickle out is correct, of course your vehicle needs to be level.
TheScarletRogue
I found out that despite using the proper torque, the torque wrench was no good and the bolt just wasn't getting tight enough. while driving I guess the pressure was just enough to make a few drops here and there.
lesson learned, always check your tools lol
datechboss101
Car: 2016 Nissan Rogue SL -- RIP
2018 Nissan Kicks SR -- RIP
2019 Nissan Rogue SV w/ Prem. Pack
Lol... You should invest in an impact gun lol... does the job 100x faster :D
akvanden
Which are the drain and fill bolts on the 2014+? There is a 10mm drain on the driver side, but there is also what looks like a drain on just opposite of it on the passenger what would be easier to get at and not spill all over my exhaust. Also, I assume the fill is the square plug on the passenger side that my extension will just fit into?
akvanden
Anyone know?
darylzero
akvanden wrote:
Fri Nov 02, 2018 1:39 pm
Anyone know?
Here is your answer:
https://www.nicoclub.com/FSM/Rogue/2015%20Rogue/ma.pdf
PaulRios
Thanks for the help, Dary.
Return to “Rogue Forum”
