I recently purchased a 1996 Pathfinder, 5 speed, 4x4. I have noticed there's a small leak under the vehicle under the center left, about under the drivers seat. I believe the leak is coming from the drain plug for the transfer case. I know that the previous owner recently had this serviced. Before replacing the plug, I need to drive about 400KM...
Will this increase the speed of the leak? Does the transfer case pressurize while the motor is running?
I was told that Redline Dexron IV fluid was used. Would that be the pink color for the fluid?
Thanks for all your help, this is a great site!
Friskin
