Hello,
FIrst time posting here, appologies if its in the wrong catagory.
I am going to change out the oil in the transfer case and differental gear oil in the differential. I would like to swap out the drain and fill bolts while I am at it as I probably wont ever do it again.
Anyways I am having trouble findering the right bolts on nissanpartzone.com
Here is what I have found:
for transfer case
http://www.nissanpartszone.com/componen ... -1502.html
i figured the drain bot is:
32103-01A0A
and filler is:
00931-2121A
As for the front diff:
My best guess is that the drain is:
32103-U840A
and fill is same as the transfer case
00931-2121A
The rear diff doesnt list anything, and I am not very knowledgable on this stuff, the website doesnt mention the LE model but my assumtion was that the SE model is close enough. Anyways just checking to see if anyone has run into this befor or better yet knows a more user friendly website.
thanks!
