Transfer begins.......
Florida240sx
Goign to begin my swap today.Hopefully by tonight old ka will be out.Tomorrow plans is to prep new engine.Get new parts for engine..Like injector o-rings which is making pull this motor. Swap oil pan's. Clean up engine bay so it's neater.Hopefully next saturday I'll drop the new KA in and be boosting by nightime.New KA(110k motor)Current motor (going to get some forgeness done to it)Phil if you're reading this I'm coming down to vero to beat you with the engine you tossed out because you had to become jdmtyte
DammitBobby
Car: S13 91 KA24DET
Goto Love it:) Probably will happen too:)
Florida240sx
Engine is about 30minutes form being pulled but have it put off till tomorrow due to light and want to eat.Everythign in engine except for power steering heating and dp(4bolt) are disconnected.Only thing left is ^^^ and to take off shifter and unbolt driveshaft.And this time my FMIC will be mounted square lol.
adoboboy
Car: s14
So your going to swap your original engine for another...beef up the original, then swap it back in?
Florida240sx
Yup.Although once built motor is ready.I'm going to push the stock block.Just hope I don't put a hole through the block.Going to max out the 555's
Chezedik
Car: 1991 Nissan 240sx
Just make sure that when it's finished that you aren't driving through Johnny Trans neighborhood with two of the big bottles (which you needed by tonight), then he shoots it. But if that happens, don't forget about the NOS!!!! Sorry, I am buzzed, and feeling like a douche'.
4felix20
Car: Emerald Blue S14
i'm about on the same page as you at the moment. healthy ka is loose and pulled, but i set it back down because i figured i'd wait until my new clutch arrived today. was already to swap it in and probably would have had it running by the end of the night, BUT enjuku sent me an sr20 clutch pressure plate. i knew right away when i was laying the plate on top of my fidanza flywheel, the bolt holes didn't match up.
i also have to swap oil pans and picked up an oil pan gasket! thought i was going to have to use silicone, but the parts store had a gasket for the ka...sweet.
AND i'm doing pretty much the same thing you are with 2 blocks. one is on the engine stand waiting for machining (wondering about torque plate for boring the cylinders..? hope it's not required)
good luck man!
Florida240sx
I'm waiting for my oil line kit to come in so I can tap the pan.It's pouring down rain so can't do anything.Got some ne winjector o ring's today. along with a couple nissan oil filter.Car is patiently waiting on boost.By then income tax will be back and I can get coilovers and maybe rims/new paint
