Trans swapping and cam issues
RoBS.
Im swapping my auto for a 5spd in my 95. My question is do i have to have a 95+ trans? Or will the s13 trans mount up to me? I need a 100% sure answer here because im going to buy it very soon. My other question is ive heard that swapping for the cams in an s13 will give me more power. Is it the s13 in general or just the 91 model. Need a 100% answer on that also because ill be purchasing them this weekend.
SilviaS14KA24DE
Car: Doriftu
th '91 cams
node
YES the cams give you more power, I have them in my S14 right now.
NO the S13 transmission will NOT WORK. The driveshaft dosent completley go into the transmission so it grinds against the collar of the S13 transmission. I just found that out the hard way. Everyone is going to tell you it works but they will be wrong. In order to use it you will have to grind the collar where the drive shaft goes into the transmission for some more clearence. I guess if you dont mind taking the time to modify the transmission it will be ok.
Let me know if you want a pic of the differances.
Jim
yellow_jacket
Car: 95 240sx
Why not just take the collar off? iirc it is just a steel piece that is pressed on.
SilviaS14KA24DE
Car: Doriftu
node, where did you get your '91 cams? how much also? power gains how much?
node
here is what I am talking about. Yes I suppose you can remove the collar since it is just press fit but I could not get it out. I suppose I could drill holes in it to get a better grip.
I got the 91 cams with a motor I picked up down in atlanta. Yea I like them the power is much smoother across the power band. I lost a little power in the low end but up top the difference is quite noticeable. You should be able to picup some at a junkyard for cheap.
node
RoBS. You know you need a MT ECU right? I have a spare 95 and 97 ecu if your interested
RoBS.
That 95 MT ECU will come in handy..name a price and ill glady buy. 95 **** is hard enough for me to come across where i live so ill take it whenever i can. Thnx :)
RoBS.
also...how much did u end up paying for a MT? and since your doing it yourself how hard is the install on a 1-10 scale? im considering doing this myself so i gotta kno whats up before i get in over my head lol. Im out in the middle of kno where in NC. The only thing around me are Mustangs and Camaros so itll be hard to find a mechanic that knows enough about the 240 to do it.
SHIFTrl240
Car: 1990 SR20 Sil-80
2009 Yamaha RoadStar Warrior
2017 Alfa Romeo Giulia Ti AWD
i spent 300 on a 96 transmission for my 13, came with driveshaft and short shift also.
yellow_jacket
Car: 95 240sx
You don't need the ecu to do the swap. Granted you will probably get a cel, but you just have to jump the shift position sensor to get it to work.
