iseenem240SX wrote:Ok, so it is only OBD1 transmissions from S13's that don't have a CAS? I guess I will need to see about replacing that sensor then.
Yes sir, 95 and up have them on the top of the bellhousing. But good luck getting to it on a 95, unless you take off the egr tube.
iseenem240SX wrote: Anyone on here do a 5 speed swap on an OBDII S14 and have absolutely no codes or problems?
I am about to finish my swap hopefully wed, and could try and answer that then. One problem I ran into was the trans harness. The plug into the engine fuse box is diff, anyone run into this? I'm using the 5 speed harness, on a previously auto car. And the top plug has 3 wires on the 5 speed harness, but the fuse box plug is only 2 prong/wire. Is this for the clutch interlock switch?
