trans removal
StricNyne
a short yet sweet question, has anyone removed the transmission without removing the motor on a rb25 in a s13 ? and if you did that mounts did you use
Kansei240sx
Car: S13 - RB25 Circuit car
71 240z - street/track day car
AE86 - Daily Drizzle/track day car
Z31t - Paper weight/street car
Tophat mounts, and i beat the firewall relentlessly. so i could get down into the top part of the bellhousing with a crows foot or just a wratchet wrench..
Another good idea i've found from experience... If you put studs into the RB25/0DET block, where the transmission goes and put nuts over the studs, its alot easier to guide the transmission back onto the motor.
RB20DETodd
Car: 92 Nissan S13 coupe SE RB20DET
i just did a clutch on my rb20 and one thing i found that was helpful or pretty much had to do it was remove the engine x member nutz and drop everything down 2 inches or so.
sean8564
Car: 1993 Nissan GT-R V-Spec
1991 Nissan 300ZX TT Black
1993 Nissan Silvia
1990 Nissan 240SX Coupe RB25DET
I loosend the Cross member and took out the drive shaft the loosend the mounts enough that i could get and extion up in that small space
BoostFab
Car: S13cp, S13fb, S14z
i did. remove the driveshaft from the transmission. drain the fluid. remove the transmission mount, let it tilt down a little bit, support the front of the motor. use a 24" or longer extension and take the bolt, starting at the starter. i used hand tools, so it's possible.
one tip, jack up the front of the motor, put some 2x4 wood blocks under so you wont crush the oil pan. this will help you get the transmission fitted back on easier. lot of bitching but you can do it.
