DFW2011M56S »
https://forums.nicoclub.com/dfw2011m56s-u266482.html
Sun Jan 29, 2017 7:58 pm
They are for all practical purposes the same. The V8 has a different valve body calibration and a different TCU flash. As far as I know the internal components are the same other than perhaps the torque converter.
I would consider both a trans cooler and an engine oil cooler in the southern climates. I am about to add both to my M56 as both get over 220°F in warmer weather with relative ease.
Install the secondary trans cooler in the return hose from the radiator cooler. Let the factory cooler pull as much heat out of the fluid as possible before allowing the auxiliary cooler to remove more. This is the setup my Express van had from the factory although I put a much larger cooler with a thermostatically controlled electric fan to compensate for towing my heavy travel trailer with a 2,600 rpm stall converter and alot more power than stock. In the same weather my Express will not top 200°F trans temp pulling a combined total of 12,500 lbs down the road.
Edit-It is also worth mentioning that a stock M56 would see even higher oil and trans temps than mine. Mine has had the Nismo thermostat in it since last summer and runs no hotter than 180°F coolant temp. Levels out about 168-170°F on the highway at cruising speeds. Stock it ran around 190-200°F.
