TRANS PROBLEMS!
djauto
HI I SWAPED A 93 TRANS INTO MY 90 EVERYTHING HOOKED UP OK NO PROBLEMS THERE!
WHEN I WAS DONE THE CAR WOULDNT START ( IFOUND THAT THE SHIFTER WOUNT GO INTO PARK ON THE TRANS) DONT KNOW WHY. I MANUALLY SHIFT IT ON THE TRANS DISCONNECTING THE SHIFTER INSIDE THE CAR AND ITS WONT GO INTO PARK. (pROBLEM ONE) I SAID THE HELL WITH THAT FOR NOW AND STARTED THE CAR BY PUTTING THE TRANS IN NEUTRAL. WHEN I PUT THE CAR IN GEAR I GET NOTHING. NO TRANS AT ALL. I KNOW THE TRANS WAS GOOD I TESTED IT LAST WEEK BEFORE PUTTING IT IN. WHAT COULD BE WRONG. NO TRANS AND CANT PUT THE TRANS INTO PARK.? THANKS
Q45tech
Didn't I point out in another forum/board that the most common installation problem is failure to mate the transmission shft with the TC proberly. Removal from one car probably has the two disengaged now.
