Trans problem.
PHReZY
Car: 300zx z32 2+2
I was driving to work witch is 20 miles and everything was fine till I got a few blocks away. I stopped at a sign and than went to go and it just started to rev as if I was in neutral. So I drifted off the the side and parked and turned it off for a few mins. Started it back up and got it in R than D and made it about a block with the speed I was able to get. Lost gear again so I repeted the step and got to work 3 blocks away. Let it sit for a few hrs and went out to take a look again. No leaks,trans fluid full pink not burnt.
Seems to catch the gear when I first start it up but than just randomly nothing happens. I hasn't having any problems before and shiftsbwere smooths even now with it acting up it still grabs smooth when i start it. Does make a whinding sound and toms jumped up to 2000rpms. Any idea what it could be ? Pump,filter?
It's a 93 2+2 auto.
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
Sounds like your valve body may have given out. My best recommendation, unfortunately, is to just go have it looked at by a reputable shop.
Either that, or auto transmissions can be had pretty cheap on ebay, if you wanna take that gamble......
