trans problem?
acside
Car: 04 G35 6sp.
its getting hard to shift into first and second gear and it seems like my trans (im pretty sure its coming from the clutch) is making a clicking noise at high rpms and throughout my driving it seems that my car is a lot louder than usual. Also when in neutral and not moving my shifter jumps every once in a while like it is catching for a quick second, at the same if the clutch is fully raised i can feel movement in the clutch pedal and the shifter. if i press the clutch the movement goes away along with the sound. Any ideas?
joe603
Car: 2014 Durango R/T
I would take it to a dealer...you might have a bad TO bearing. Has the fluid been checked recently?
WECHSLERL
Car: G35
HOW MANY MILES ON THE CAR/CLUTCH
LW
