TRANS NOT SHIFTING INTO 4TH GEAR
allah1
Car: 1993 Q45A
WHAT WOULD CAUSE MY 93 Q45 TO NOT SHIFT INTO 4TH GEAR? COULD IT BE A BAD SPEED SENSOR OR DO YOU THINK I HAVE SOME GUNK BUILD UP IN THE transmission AND NEED TO FLUSH IT. SOMEONE PLEASE GIVE ME SOME INSIGHT?
Q45tech
Follow the dignostic proceedure in FSM to activate on board display to AT check mode.
1st and 4 th gear require that Solenoid A cycle on...........does 1st gear work?
Have a dealer use Consult to check for transmission codes and drive proceedure.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
allah1 wrote:SOMEONE PLEASE GIVE ME SOME INSIGHT?
OK, here goes. Please disengage the CAPS LOCK key as it is considered SHOUTING when posting.
For the transmission difficutly, follow Q45tech's advice.
allah1
Car: 1993 Q45A
1st through 3rd works fine so do you have any ideas why it wont shift into 4th? i get up to around 75mph and it doesn't go into 4
Q45tech
What happens when you select 3 gear position at 75 mph............checking to make sure the selector vs under car gear switches are aligned correctly.
